Syslog and Process Logs Configuration
This section describes how to configure syslog and process log servers.
To configure syslogs and process logs:
In Superuser mode,
type
configure
terminal and press Enter.
ORACLE# configure terminal
Type
system and press
Enter to access the system-level configuration elements.
ORACLE(configure)# system
Type
system-config and
press Enter. The system prompt changes to let you know that you can begin
configuring individual parameters.
ORACLE(system)# system-config ORACLE(system-config)#
From this point, you can set process log parameters. Skip to the following process log configuration section.
Type
syslog-server and
configuring individual syslog parameters
ORACLE(system-config)# syslog-server
ORACLE(syslog-config)#
From this point, you can set syslog parameters. The following is an example what an syslog and process log configuration might look like. Parameters not described in this section are omitted below.
system-log-level WARNING syslog-server address 172.15.44.12 port 514 facility 4 process-log-level NOTICE process-log-ip-address 0.0.0.0 process-log-port 0
