H.323 HNT Configuration
You can enable this capability for specific H.323 interfaces.
To enable H.323 HNT:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the session-related configurations.
ORACLE(configure)# session-router
Type
h323
and press Enter.
ORACLE(session-router)# h323
Type h323-stack and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters for the H.323 interface.
ORACLE(h323)# h323-stack
If you are adding this service to a new H.323 interface that you are creating, type
options hnt (to enable H.323 HNT), and then press Enter.
ORACLE(h323-stack)# options hnt
If you are adding this service to an H.323 interface that already exists, type
select to select the interface to which you want to add the service. Then use the options command and prepend the option with a plus (+) sign.
If you know the same of the interface, you can type the name of the interface at the name: prompt and press Enter.
If you do not know the name of the interface, press Enter at the name: prompt. A list of interfaces will appear. Type the number corresponding to the interface you want to modify, and press Enter.
If are adding service to an existing interface and you type options hnt without a plus (+) sign, you will remove any previously configured options. In order to append the new option to the options list, you must prepend the new option with a plus sign as shown in the example above.
