PreviousNextJavaScript must be enabled to correctly display this content
SIP Delayed Media Update Configuration
You enable this feature on a per-realm basis by setting one parameter.
To enable SIP delayed media update:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager
and press Enter to access the signaling-related configurations.
ORACLE(configure)# media-manager
Type
realm-config
and press Enter.
ORACLE(media-manager)# realm-config
If you are adding support for this feature to a pre-existing realm, then you must select (using the ACLI
select command) the realm that you want to edit.
delay-media-update—Enable keeping the
Oracle® Enterprise Session Border Controller from updating its media flow information for flows established after an offer/answer exchange. The default is
disabled. The valid values are:
