IWF Inband Tone Configuration
To configure the IWF inband tone option:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the media-related configurations.
ORACLE(configure)# session-router
Type
h323
and press Enter.
ORACLE(session-router)# h323
Type
h323-stacks and press Enter.
ORACLE(h323)# h323-stacks ORACLE(h323-stacks)#
Use the ACLI
select command add this feature to an existing H.323 interface.
ORACLE(h323-stacks)# select
If you are adding this service to a new H.323 interface, type
option inbandTone and press Enter.
ORACLE(h323-stacks)# option inbandTone
If you are adding this service to an H.323 interface that already exists, type
select to select the interface to which you want to add the service. Then use the options command and prepend the option with a plus (+) sign.
If you know the same of the interface, you can type the name of the interface at the name: prompt and press Enter.
If you do not know the name of the interface, press Enter at the name: prompt. A list of interfaces will appear. Type the number corresponding to the interface you want to modify, and press Enter.
If are adding service to an existing interface and type in the option without a plus (+) sign, you will remove any previously configured options. In order to append the new option to the options list, you must prepend the new option with a plus sign: options +inbandTone.
