Blocking Actions
Blocking actions include the following:
- Dynamic deny entry added, which can be viewed through the ACLI.
- SNMP trap generated, identifying the malicious source
Dynamically added deny entries expire and are promoted back to untrusted after a configured default deny period time. You can also manually clear a dynamically added entry from the denied list using the ACLI.
