P-Preferred-Identity Configuration
To enable the inclusion of P-Preferred-Identity:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
session-agent and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# session-agent ORACLE(session-agent)#
Select the session agent where you want to apply this feature.
ORACLE(session-agent)# select <hostname>: 1: 204.12.60.5 realm=private 2: 124.21.5.3 realm=public selection:1 ORACLE(session-agent)#
options—Set the options parameter by typing
options, a Space, the option name preceded by a plus sign (+) (PPreferredId), and then press Enter.
ORACLE(realm-config)# options +PPreferredId
If you type options PPreferredId, you will overwrite any previously configured options. In order to append the new option to the session agent’s options list, you must prepend the new option with a plus sign as shown in the previous example.
- Save and activate your configuration.
