Configuring the Local Policy Attribute
You can specify that an ENUM query needs to be done for the routing of SIP calls. You do so by configuring the local policy’s next-hop attribute with the name of a specific ENUM configuration, prefixed with the enum: tag. For example: enum:test
You can configure multiple next-hops with different ENUM servers or server groups (possibly with different top-level-domains). If the first ENUM server group you enter as the next hop is not available, one of the others can be used.
A new parameter called action has replaced the policy attribute’s replace-uri parameter available prior to build 211p19.To configure local policy:
