PreviousNextJavaScript must be enabled to correctly display this content
Dialog Transparency Configuration
You set one parameter in your SIP configuration to enable dialog transparency.
For new configurations, this feature defaults to enabled
To enable SIP dialog transparency:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the
session-router path.
ORACLE(configure)# session-router
Type
sip-config
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-config
Use the ACLI
select command so that you can work with the SIP configuration.
ORACLE(sip-config)# select
dialog-transparency—Enter the state of SIP dialog transparency you require for your
Oracle® Enterprise Session Border Controller. The default value is
enabled. The valid values are:
