SIP TCP Connection Reuse Configuration
This section describes how to enable SIP TCP connection reuse for a session agent. Currently there are two options for the new reuse-connections parameter: none (which turns the feature off) and tcp (which enables the feature for TCP connections). You also set the re-connection interval.
To enable SIP TCP connection reuse for a session agent:
