Listing Backups You can view the backups available on your system using the display-backups command. To list available backup configurations: In Superuser mode, enter the display-backups command. A list of available backup files from the /code/bkups directory is displayed on the screen. ORACLE# display-backups test_config.tar.gz test-config.tar.gz runningcfgtest.tar.gz runningtest_one.tar.gz BACK_UP_CONFIG.tar.gz 02_Feb_2008.tar.gz 01_Feb_2008.tar.gz ORACLE#
