Modified ALCI Configuration Elements
The action parameter in security-policy configuration mode has been modified to accept additional values, srtp and srtcp.
From superuser mode, use the following command sequence to access media-sec-policy configuration mode.
ORACLE# configure terminal ORACLE(configure)# security ORACLE(security)# ipsec ORACLE(ipsec)# security-policy ORACLE(security-policy)# action ? <enumeration> action (default: ipsec) ipsec, allow, discard, srtp, srtcp ORACLE(security-policy)#
Refer to Security Policy for sample Security Policies.
The show security command has been updated with an srtp option.
ORACLE# show security srtp sad spd statistics SRTP Statistics statusThe srtp option is similar to the ipsec option save for the sad sub-option that provides data for only SRTP SAs.
The show sa stats command has been updated with an srtp option.
ORACLE# show sa stats <ENTER> Show statistics summary of all Security Associations <ike> Show statistics for IKE Security Associations <ims-aka> Show statistics for IMS-AKA Security Associations <srtp> Show statistics for SRTP Security Associations sd# show sa stats srtp 20:06:24-114 SA Statistics ---- Lifetime ---- Recent Total PerMax SRTP Statistics ADD-SA Req Rcvd 0 0 0 ADD-SA Success Resp Sent 0 0 0 ADD-SA Fail Resp Sent 0 0 0 DEL-SA Req Rcvd 0 0 0 DEL-SA Success Resp Sent 0 0 0 DEL-SA Fail Resp Sent 0 0 0
