Sample SIP NOTIFY with NATed XML
The following is a sample SIP NOTIFY message as it might arrive at the
Oracle® Enterprise Session Border Controller.
that it contains the <di:remote-uri> or <di:local-uri> XML tags on which the system will perform NAT; these lines appear in bold text.NOTIFY sip:15615281021@10.152.128.253:5137;transport=udp SIP/2.0
To: 15615281021 <sip:15615281021@10.152.128.102:5080>;tag=5c93d019904036a
From: <sip:15615281021@10.152.128.102:5080>;tag=test_tag_0008347766
Call-ID: 3215a76a979d0c6
CSeq: 18 NOTIFY
Contact: <sip:15615281021@10.152.128.102:5080;maddr=10.152.128.102>
Via: SIP/2.0/UDP 10.152.128.102:5060;branch=z9hG4bK_brancha_0023415201
Event: keyset-info
Subscription-state: active;expires=2778
Accept: application/keyset-info+xml
Content-Type: application/keyset-info+xml
Content-Length: 599
Max-Forwards: 70
<?xml version="1.0"?>
<keyset-info xmlns="urn:ietf:params:xml:ns:keyset-info"
version="16"
entity="15615281021">
<ki-data>
<ki-state>"active"</ki-state>
<ki-event>"unknown"</ki-event>
</ki-data>
<di:dialog id="dialog_id_201" call-id="1395216611-1987932283256611-11-0884970552" local-tag="test_tag_0008347790" direction="recipient">
<di:state>trying</di:state>
<di:duration>2778</di:duration>
<di:local-uri>sip:15615281021@10.152.128.253:5137</di:local-uri>
<di:remote-uri>sip:1004@10.152.128.102</di:remote-uri>
</di:dialog>
</keyset-info>
Once the Oracle® Enterprise Session Border Controller has completed the NAT process, the <di:remote-uri> and <di:local-uri> XML tags look like this
<di:local-uri>sip:15615281021@192.168.200.99:5137</di:local-uri> <di:remote-uri>sip:1004@192.168.200.49</di:remote-uri>
because egress the SIP interface’s IP address is 192.168.200.49 and the next hop’s IP address is 192.168.200.99.
This feature does not require any configuration.
