| Register host
Enter the registrar’s hostname to be used in the Request-URI of the REGISTER request. This name is also used as the host portion of the AoR To and From headers.
| Register user
Enter the user portion of the AoR (Address of Record).
| Description
Optional. Enter a description of this surrogate agent.
| Realm ID
Enter the name of realm where the surrogate agent resides (where the IP-PBX proxy resides). There is no default.
| State
Set the state of the surrogate agent to indicate whether the surrogate agent is used by the application. The default value is
enabled.
| Customer host
Optional. Enter the domain or IP address of the IP-PBX, which is used to determine whether it is different than the one used by the registrar.
| Customer next hop
Enter the next hop to this surrogate agent:
- session agent group: <session agent group name>
- session agent: <hostname> or <IPV4>
| Register contact host
Enter the hostname to be used in the Contact-URI sent in the REGISTER request. This should always point to the
E-SBC. If specifying a IP address, use the egress interface’s address. If there is a SIP NAT on the registrar’s side, use the home address in the SIP NAT.
| Register contact user
Enter the user part of the Contact-URI that the
E-SBC generates.
| Password
If you are configuring the auth-user parameter, you need to enter the password used when the registrar sends the 401 or 407 response to the REGISTER request.
| Register expires
Enter the expires in seconds for the REGISTER requests. The default value is
600,000 (1 week). The valid range is 0-999999999.
| Replace contact
This specifies whether the
E-SBC needs to replace the Contact in the requests coming from the surrogate agent. If this is enabled, Contact will be replaced with the Contact-URI the
E-SBC sent in the REGISTER request. The default value is
disabled. The valid values are enabled and disabled.
| Options
Optional. Enter non-standard options or features.
| Route to registrar
This indicates whether requests coming from the surrogate agent should be routed to the registrar if they are not explicitly addressed to the
E-SBC. The default value is
enabled. The valid values are enabled and disabled.
| AoR count
Enter the number of registrations to do on behalf of this IP-PBX. If you enter a value greater than
1, the
E-SBC increments the register-user and the register-contact-user values by that number. For example, if this count is 3 and register-user is john then users for three different register messages will be john, john1, john2. It does the same for the register-contact-user values. The default value is
1. The valid range is 0-999999999.
| Auth user
Enter the authentication user name you want to use for the surrogate agent. This name is used when the
E-SBC receives a 401or 407 response to the REGISTER request and has to send the REGISTER request again with the Authorization or Proxy-Authorization header. The name you enter here is used in the Digest username parameter. If you do not enter a name, the
E-SBC uses the value of the register-user parameter.
| Max register attempts
Enter the total number of times to attempt registration until success. Range 1-10
| Registry retry time
Enter the time to wait after an unsuccessful registration before re-attempting. Range 30-3600
| Count start
Enter the starting value for numbering when performing multiple registrations. Range 0-9999999999
| Register mode
Select automatic (default) or triggered (upon trigger from PBX).
| Triggered inactivity interval
Enter the maximum time with no traffic from the corresponding PBX. (Valid only with Triggered inactivity interval.) Range 5 -300
| Triggered OoS response
503 (Default. Send 503 response for core network failure) or drop response (Do not respond to PBX or core network failure
