Home Realm Configuration
To configure the home realm:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type
sip-config and press Enter. The system prompt changes.
ORACLE(session-router)# sip-config ORACLE(sip-config)#
From this point, you can configure SIP configuration parameters. To view all sip-config parameters, enter a ? at the system prompt.
home-realm-id—Enter the name of the realm you want to use for the realm ID. For example,
acme.
The name of the realm must correspond to the identifier value you entered when you configured the realm.
egress-realm-id—Optional. Enter the egress realm ID to define the default route for SIP requests addressed to destinations outside the home realm’s address prefix.
If you enter a value for this optional field, it must correspond to the identifier value you entered when you configured the realm.
You should leave this parameter blank for access/backbone applications. When left blank, the realm specified in the home-realm-id parameter is used by default. -
nat-mode—Indicate the SIP NAT mode. The default is
none. The valid values are:
public—Indicates the subnet defined in the addr-prefix-id field of the home realm is public and the subnet defined in the addr-prefix-id field of all external realms identified in the SIP NAT are private networks. IPv4 addresses are encoded in SIP messages received from the external realm defined by the SIP NAT. The IPv4 addresses are decoded in messages that are sent to the realm.
private—Indicates the subnet defined in the addr-prefix-id field of the home realm is private and the subnet defined in the addr-prefix-id field of all external realms identified in the SIP NAT are public networks. IPv4 addresses are encoded in SIP messages sent to the external realm defined by the SIP NAT and decoded in messages received from the realm.
none—No SIP NAT function is necessary.
The following example shows the SIP home realm configured for a peering network.
sip-config state enabled operation-mode dialog dialog-transparency disabled home-realm-id acme egress-realm-id nat-mode Public registrar-domain registrar-host registrar-port 0 init-timer 500 max-timer 4000 trans-expire 32 invite-expire 180 inactive-dynamic-conn 32 red-sip-port 1988 red-max-trans 10000 red-sync-start-time 5000 red-sync-comp-time 1000 last-modified-date 2005-03-19 12:41:28
