PreviousNextJavaScript must be enabled to correctly display this content
TLS Session Caching Configuration
TLS session caching is global for all TLS functions on your
Oracle® Enterprise Session Border Controller. A new global TLS configuration (tls-global) has been added to the system for this purpose.
To enable global TLS session caching:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
security and press Enter to access the signaling-level configuration elements.
ORACLE(configure)# securityORACLE(security)#
Type
tls-global
and press Enter.
ORACLE(security)# tls-globalORACLE(tls-global)#
session-caching—Set the state for TLS session caching to
enabled if you want to turn this feature on. The default value is
disabled. The valid values are:
enabled | disabled
session-cache-timeout—Enter the time in hours that you want the
Oracle® Enterprise Session Border Controller to cache unique session identifiers so that previously authenticated clients can reconnect. The default value is
12. A value of
0 disables this parameter. The valid range is:
Minimum—0
Maximum—24
If you set this parameter to 0, then cache entries will never age (and not be deleted from the cache unless you use the
clear-cache tls command to delete all entries from the TLS cache). RFC 2246,
The TLS Protocol Version 1.0, recommends that you set this parameter at the maximum, 24.
