PreviousNextJavaScript must be enabled to correctly display this content
Applying Session Constraints in a SIP Interfaces
In the SIP interface, there is a new parameter that allows you to use a set of session constraints for that interface; the parameter is called constraint-name.
To apply session constraints to a SIP interface:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router
Type
sip-interface and press Enter.
ORACLE(session-router)# sip-interface
constraint-name—Enter the name of the session constraints configuration that you want to apply to this SIP interface. There is no default for this parameter.
