PreviousNextJavaScript must be enabled to correctly display this content
Set up the Playback Configuration
The playback configuration defines the media files that you want to play, listed by codec. Each codec encoding that you want to support requires its own file, defined by the playback entry sub-element.
Procedure
In Superuser mode, type
configure terminal, and press Enter.
ACMEPACKET# configure terminal
Type
media-manager, and press Enter.
ACMEPACKET(configure)# media
ACMEPACKET(media-manager)#
name—Enter the name of this playback configuration. This parameter has no default, and is required. You use this name when you configure the spl-options parameter; it specifies the media the
Oracle® Enterprise Session Border Controller (E-SBC) plays.
entries—Configure the entries for this playback configuration. These entries refer to files in the /code/media directory, and are designed so that you can reference the same media with different codecs. For example, you might want to be able to play the same playback tone in different codecs; here, you would specify the file name and the encoding for each one you have stored.
encoding—Enter the codec name for this media file entry, such as PCMU. This value must match the encoding name negotiated in the SDP. This parameter has no default and is required.
filename—Enter the name of the raw binary media file you stored in the /code/media directory on the
E-SBC.
bytes-per-second—Enter the playback rate for this media file in bytes per second. Default: to 8000. Range:100-99999.
