DiffServ Byte
Given that the TOS byte was rarely used, the IETF redefined it and in doing so created the DiffServ byte.
The DiffServ byte format is as follows:
The DiffServ codepoint value is six bits long, compared to the three-bit-long TOS byte’s precedence component. Given the increased bit length, DiffServ codepoints can range from 000000 (decimal 0) to 111111 (decimal 63).
By default, DiffServ codepoint mappings map exactly to the precedence component priorities of the original TOS byte specification.
