H.245 Stage Configuration
To configure H.245 stage support:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the media-related configurations.
ORACLE(configure)# session-router
Type
h323
and press Enter.
ORACLE(session-router)# h323
Type
h323-stacks and press Enter.
ORACLE(h323)# h323-stacks ORACLE(h323-stacks)#
h245-stage—Set this field to the stage at which the
Oracle® Enterprise Session Border Controller transfers the H.245 address to the remote side of the call, or acts on the H.245 address sent by the remote side. The default value is
Connect. Valid values are:
Setup | Alerting | Connect | Proceeding | Early | Facility | noh245 | Dynamic
