Setting the Element Type
In the element rules (a subset of the SIP header rules configuration), you can now set the type parameter to either of the following values, both of which will only have an impact on the status-line:
- status-code—Designates the status code of the response line; accepts any string, but during the manipulation process only recognizes the range from 1 to 699
- reason-phrase—Designates the reason of the response line; accepts any string
Like other rule types you can set, the Oracle® Enterprise Session Border Controller matches against the value for these using case-sensitive, case-insensitive, or pattern-rule matching (set in the comparison-type parameter for the element rule).
To set the element type:
