LRT Entry Matching Configuration
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router
Type
local-routing-config
and press Enter.
ORACLE(session-router)# local-routing-config ORACLE(local-routing-config)#
- match-mode—Set this parameter to either best, all, or leave it as exact which is the default. This indicates to the Oracle® Enterprise Session Border Controller how to determine LRT lookup matches.
- Save your work using the done command.
