LDAP Error Messages
The ESD displays errors messages if the LDAP configuration objects are not properly configured. The following error messages for LDAP may display:
For all ldap-config objects:
- if an ldap-tls-profile is
specified, and a tls-profile with that name has not been configured, the
following error displays:
ERROR: ldap-config [xyz] has reference to tls-profile [abc] which does not exist.
- if a realm has not been
configured for an ldap-config, the following error displays:
ERROR: ldap-config [xyz] has reference to realm [abc] which does not exist.
For all ldap-cfg-attributes:
For local policy-attributes:
- if the ldap-config object is
configured corresponding to every ldap-config specified in the next-hop(s) in
all policy-attribute subelements, and the
next-hop value is not recognized,
ERROR: local-policy-attribute [route; ldap:ldap-config-name] from local-policy [xyz] has reference to next-hop [ldap:ldap-config-name] which does not exist
not enabled, the following error displays:
ERROR: local-policy-attribute [route; ldap:ldap-config-name] from local-policy [xyz] has reference to next-hop [ldap:ldap-config-name] which is not enabled
