Configuring Utilization Thresholds for Media Interfaces
To configure utilization thresholds for media interfaces:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
system and press Enter.
ORACLE(configure)# system ORACLE(system)#
Type
phy-interface
and press Enter.
If you are adding this feature to an existing configuration, then remember you must select the configuration you want to edit.
ORACLE(system)# phy-interface ORACLE(phy-interface)#
Type
network-alarm-threshold
and press Enter.
ORACLE(phy-interface)# network-alarm-threshold ORACLE(network-alarm-threshold)#
- severity—Enter the severity for the alarm you want to fine for this interface: minor (default), major, or critical. Since the parameter defaults to minor, you must change the value if you want to define a major or critical alarm.
- value—Enter the percentage of utilization (transmitting and receiving) for this interface that you want to trigger the alarm. For example, you might define a minor alarm with a utilization percentage of 50. Valid values are between 0 and 100, where 0 is the default.
- Save your work.
