Configuring the CN Generation SPL
Use the following procedure to configure the CN Generation SPL on the Net-Net ESD.
- The CN Generation SPL can be installed on the Server Edition and VMWare (preferred hypervisor) platforms, only.
- You must have the SPL loaded and enabled using the procedure in Loading and Enabling the SPL.
To configure the CN Generation SPL:
