Interworking Gatekeeper-Gateway
This example provides is a sample for the Interworking Gatekeeper-Gateway mode of operation.
h323-config
state enabled
log-level INFO
response-tmo 4
connect-tmo 32
h323-stack
name zone1
state enabled
isgateway disabled
realm-id zone1realm
assoc-stack zone2
local-ip x.x.x.x(IP address of VGW-A/GK-A)
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=private
ras-port 1719
auto-gk-discovery disabled
multicast 0.0.0.0:0
gatekeeper x.x.x.x(IP address of GkZone1)
gk-identifier gk-zone1.acme.com
q931-port 1720
alternate-transport
q931-max-calls 200
h245-tunneling enabled
fs-in-first-msg disabled
call-start-fast disabled
call-start-slow disabled
media-profiles
process-registration disabled
anonymous-connection disabled
proxy-mode
filename
h323-stack
name zone2
state enabled
isgateway enabled
realm-id DomainCrealm
assoc-stack zone1
local-ip x.x.x.x(IP address of VGW-C)
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=acme01
ras-port 1719
auto-gk-discovery enabled
multicast 0.0.0.0:0
gatekeeper 0.0.0.0:0
gk-identifier gk-zone2.acme.com
q931-port 1720
alternate-transport
q931-max-calls 200
media-profiles
proxy-mode
filename
h323-stack
name zone3
state enabled
isgateway disabled
realm-id zone3realm
assoc-stack zone4
local-ip x.x.x.x(IP address of VGW-B/GK-B)
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=private
ras-port 1719
multicast 0.0.0.0:0
gatekeeper x.x.x.x(IP address of GkZone3)
gk-identifier gk-zone3.acme.com
q931-port 1720
alternate-transport
q931-max-calls 200
media-profiles
proxy-mode
filename
h323-stack
name zone4
state enabled
isgateway enabled
assoc-stack zone3
local-ip x.x.x.x(IP address of VGW-D)
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=private
ras-port 1719
multicast 0.0.0.0:0
gatekeeper x.x.x.x(IP address of GkZone4)
gk-identifier gk-zone4.acme.com
