PreviousNextJavaScript must be enabled to correctly display this content
Removing the T.38 Codec from an H.245 TCS
For SIP-H.323 IWF sessions, H.323 automatically inserts the T.38 FAX codec in the H.246 TCS message. You can stop this insertion using the remove-t38 parameter in the H.323 global configuration.
