Embedded Header Support Configuration
Embedded header support is enabled in the session agent configuration.
To configure embedded header support:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type
session-agent and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# session-agent ORACLE(session-agent)#
Select the session agent where you want this feature.
ORACLE(session-agent)# select <hostname>: 1: asd realm= ip=1.0.0.0 2: SIPSA realm= ip=10.10.102.1 selection:2 ORACLE(session-agent)#
request-uri-headers—Enter a list of embedded headers extracted from the Contact header that will be inserted in the re INVITE message.
To configure this parameter for multiple headers, enclose the headers in double quotes and separate them with spaces. This completes the configuration of embedded header support.
ORACLE(session-agent)# request-uri-headers P-Asserted-Identity
