H. 323 System Resource Allocation
You can set the following parameters to determine how many concurrent calls and concurrent channels you want to allow for each H.323 interface.
To allocate H.323 system resources:
max-calls—Enter the maximum number of concurrent calls allowed on this H.323 interface. The default value is
200. The valid range is:
Minimum—0
Maximum—4294967295
max-channels—Enter the maximum number of concurrent channels allowed for each call associated with this H.323 interface. The default value is
6. The valid range is:
Minimum—0
Maximum—4294967295
The Oracle® Enterprise Session Border Controller checks this parameter on initialization to reserve the appropriate network resources.
