PreviousNextJavaScript must be enabled to correctly display this content
Configuring the PPM Proxy on the Net-Net ESD
To configure the PPM proxy on the Net-Net ESD, you use the
http-alg object under session-router, and the
http-alg-private or
http-alg-public settings. Use the following procedure to configure the PPM proxy on the Net-Net ESD.
To configure the PPM proxy:
In Superuser mode, type
configure terminal and press Enter.
name—Enter the name (unique identifier) of the HTTP proxy. Valid values are alpha-numeric characters. Default is blank.
state—Enter the operational status of the HTTP proxy. Valid values are:
enabled - (default) Enables the HTTP proxy.
disabled - Disables the HTTP proxy.
description—Enter a description of the HTTP proxy. Valid values are alpha-numeric characters. Default is blank.
private—Allows you to configure a private/core-side interface (inside the network) for forwarding the incoming HTTP SOAP Requests received from the public side.
public—Allows you to configure a public-side interface (outside the network) to receive incoming HTTP SOAP Requests from the remote worker.
