Configuring a Session Agent for SIP Route Recursion
To configure SIP Route recursion for an existing session agent:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the session-router path.
ORACLE(configure)# session-router
Type
session-agent and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# session-agent ORACLE(session-agent)#
Select the session agent where you want this feature.
ORACLE(session-agent)# select <hostname>: 1: asd realm= ip=1.0.0.0 2: SIPSA realm= ip=10.10.102.1 selection:2 ORACLE(session-agent)#
stop-recurse—Enter list of returned response codes that this session agent will watch for in order to stop recursion on the target’s or contact’s messages. This can be a comma-separated list or response code ranges.
ORACLE(session-agent)# stop-recurse 404,484-486
- Save and activate your changes.
