Configuring the Certificate Record
The certificate record configuration represents either the end-entity certificate or the CA certificate on the Oracle® Enterprise Session Border Controller (E-SBC). When you use the certificate record for an end-entity certificate, associate a private key with the certificate record configuration by using the ACLI generate-certificate-request command. You can import a requested certificate provided by a CA into a certificate record configuration using the ACLI import-certificate command.
Do not associate a private key with the certificate record configuration, if it was issued to hold a CA certificate.
You do not need to create a certificate record when importing a CA certificate or certificate in PKCS #12 format.- Create TLS profiles, using your certificate records, to further define the encryption behavior and create the configuration element that you can apply to a SIP interface.
