Media Profile Configuration for Generic Audio Support
To set a media profile for generic audio support:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router and press Enter.
ORACLE(configure)# session-router
Type
media-profile
and press Enter.
ORACLE(session-router)# media-profile ORACLE(media-profile)#
- name—Set the name of the generic audio media profile to genericAudioCapability. There is no default for this parameter.
media-type—Set the media type to use for this media profile; for generic video, set this parameter to
audio. Valid values are:
audio | video | application | data
- payload-type—Set the payload type to use for the generic audio media profile.
transport—Set the transport type to use for the generic audio media profile. The default value is
RTP/AVP. Valid values are:
UDP | RTP/AVP
- Complete the rest of the media profile configuration as needed.
Save and activate your configuration.
The following is a sample of a generic audio media profile configuration:
media-profile name genericAudioCapability media-type audio payload-type 104 transport RTP/AVP req-bandwidth 0 frames-per-packet 0 parameters average-rate-limit 0 sdp-rate-limit-headroom 0 sdp-bandwidth disabled
