Example 3 Installing Only Static ACLs
This example shows you how to prevent the Oracle® Enterprise Session Border Controller from installing the global permit (0.0.0.0) untrusted ACL.
- Configure a realm with a trust level of none.
- Configure static ACLs for that realm with the same source address prefix as the realm’s address prefix, and set the trust level to any value.
The system installs only the static ACLs you configure.
