Configuring the Certificate Record
The certificate record configuration represents either the end-entity or the Certificate Authority (CA) certificate on the Net-Net ESD. If it is used to present an end-entity certificate, a private key should be associated with this certificate record configuration using the ACLI security certificate request command.
No private key should be associated with the certificate record configuration if it was issued to hold a CA certificate. A certificate can be imported to a certificate record configuration using the ACLI security certificate import command.
There is no need to create a certificate record when importing a CA certificate or certificate in pkcs12 format.To configure a certificate:
