Media Inactivity Timer Configuration
To disable the media inactivity timer for calls placed on hold:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router
and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
session-agent
and press Enter.
ORACLE(session-router)# session-agent ORACLE(session-agent)#
If you are adding support for this feature to a pre-existing configuration, then you must select (using the ACLI select command) the configuration you want to edit.
- invalidate-registration—Set this parameter to enabled if you want to use the manual trigger to send this session agent offline (and therefore invalidate the registrations associated with it). The default is disabled.
- Save and activate your configuration.
