Examples
| Ex | Messages on Originating Call Leg | Ingress SIP Interface Config | Ingress SIP Interface Config | Messages on Terminating Call Leg |
| 1 | INVITE → Supported: timer SE: 200 ────────────────── ← 200 OK Require: timer SE: 200; refresher=uas |
session-expires: 500 min-se: 200 request-refresher: none response-refresher: uas this element becomes refresher |
session-expires: 500 min-se: 400 request-refresher: none response-refresher: uas |
INVITE→ Supported: timer SE: 500 Min-se: 400 ────────────────── ← 200 OK Require: timer SE: 400; refresher=uas |
| 2 | INVITE → Supported: timer SE: 1200; refresher=uas ────────────────── ← 200 OK Require: timer SE: 500; refresher=uas |
session-expires: 500 min-se: 200 request-refresher: none response-refresher: uac this element becomes refresher |
session-expires: 500 min-se: 400 request-refresher: uas response-refresher: uas this element becomes refresher |
INVITE → Supported: timer SE: 500; refresher=uas Min-se: 400 ────────────────── ← 200 OK |
| 3 | INVITE → Supported: timer SE: 1200; refresher=uac Min-se: 800 ────────────────── ← 200 OK Require: timer SE: 800; refresher=uac |
session-expires: 500 min-se: 200 request-refresher: none response-refresher: uas |
No session timer configuration this element becomes refresher |
INVITE → Supported: timer ────────────────── ← 200 OK Require: timer SE: 400; refresher=uac |
| 4 | INVITE → Supported: timer SE: 200; refresher=uac ────────────────── ← 200 OK Require: timer SE: 200; refresher=uac |
No session timer configuration | INVITE → Supported: timer ────────────────── ← 200 OK |
| 5 | INVITE → Supported: timer SE: 200 ────────────────── ← 200 OK |
No session timer configuration | session-expires: 500 min-se: 400 request-refresher: uas response-refresher: uas this element becomes refresher |
| 6 | INVITE → Supported: timer SE: 200 ────────────────── ← 200 OK Require: timer SE: 400; refresher=uas |
No session timer configuration SBC behavior stays same as current behavior |
No session timer configuration | INVITE → Supported: timer SE: 200 ────────────────── ← 200 OK Require: timer SE: 400; refresher=uas |
| 7 | INVITE → Require: timer SE: 200 ────────────────── ← 420 Unsupported: timer |
No SIP feature for timer No session timer configuration SD behavior stays same as current behavior |
No session timer configuration | |
| 8 | INVITE → Require: timer SE: 200 ────────────────── ← 420 Unsupported: timer |
SIP feature configured for timer No session timer configuration SD behavior stays same as current behavior |
No session timer configuration | INVITE → Required: timer SE: 200 ────────────────── ← 420 Unsupported: timer |
| 9 | INVITE → Require: timer SE: 200 ────────────────── ← 200 OK |
SIP feature configured for timer No session timer configuration |
session-expires: 500 min-se: 400 request-refresher: none response-refresher: uas this element becomes refresher |
INVITE → Supported: timer SE: 500 Min-se: 400 ────────────────── ← 200 OK Require: timer SE: 500; refresher=uac |
| 10 | INVITE → Require: timer SE: 200 ────────────────── ← 200 OK Require: timer SE: 200; refresher=uac |
No SIP feature for timer session-expires: 500 min-se: 200 request-refresher: none response-refresher: uac |
session-expires: 500 min-se: 400 request-refresher: uas response-refresher: uas |
INVITE → Supported: timer SE: 500; refresher=uas Min-se: 400 ────────────────── ← 200 OK Require: timer SE: 500; refresher=uas |
| 11 | INVITE → Require: timer SE: 200 ────────────────── ← 420 Unsupported: timer |
No SIP feature for timer No session timer configuration |
| 12 | INVITE → SE: 200 ────────────────── ← 200 OK SE: 500; refresher=uas |
session-expires: 500 min-se: 500 request-refresher: none response-refresher: uas this element becomes refresher |
No session timer configuration | INVITE → ────────────────── ← 200 OK |
| 13 | INVITE → ────────────────── ← 200 OK |
No session timer configuration | session-expires: 500 min-se: 400 request-refresher: none response-refresher: uas |
INVITE → Supported: timer SE: 500 Min-se: 400 ────────────────── ← 200 OK Require: timer SE: 400; refresher=uas |
| 14 | INVITE → ────────────────── ← 421 Require: timer |
| 15 | INVITE → Supported: timer SE: 200 ────────────────── ← 422 Min-se: 400 |
session-expires: 500 min-se: 400 |
| 16 | INVITE → Supported: timer SE: 200 ────────────────── ← 200 OK Require: timer SE: 200; refresher=uac |
session-expires: 800 min-se: 90 request-refresher: none response-refresher: uac |
INVITE → Supported: timer SE: 800 Min-se: 90 ────────────────── ← 422 Min-se: 900 ────────────────── INVITE → Supported: timer SE: 900 Min-se: 900 ────────────────── ← 200 OK Require: timer SE: 900; refresher=uas |
