About SIP Header and Parameter Manipulation
Using the SIP header manipulation ruleset, you can cause the Oracle® Enterprise Session Border Controller to:
- Delete a header based on header name match.
- Delete a header based on header name match as well as header value match.
- Add a header.
- Modify the elements of a header (by configuring header element rules):
Add an element to a header.
For example, add a parameter to a header or add a URI parameter to the URI in a header.
Delete an element from a header.
For example, delete a parameter from a header or delete a URI parameter from the URI in a header.
Modify an element of a header.
For example, replace a FQDN with an IPv4 address in a header or replace the value of a parameter in the header.
Delete a message body part
For example, delete the body part if the Content-Type is application/ISUP.
