DTMF Transparency Configuration
To enable DTMF transparency for SIP/H.323 IWF:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
media-manager and press Enter.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
media-manager and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(media-manager)# media-manager ORACLE(media-manager-config)#
- translate-non-rfc2833-event—To enable this feature, set this parameter to enabled. If you do not want to use the feature leave it set to its default behavior, disabled.
- Save and activate your configuration.
