SIP per User CAC Configuration
Note that you must enable registration caching for this feature to work.
To configure SIP per user CAC:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
realm-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(media-manager)# realm-config ORACLE(realm-config)#
Select the realm where you want to want to add SIP per user CAC.
ORACLE(realm-config)# select
user-cac-mode—Set this parameter to the per user CAC mode that you want yo use. The default value is
none. The valid values are:
none—No user CAC for users in this realm
aor—User CAC per AOR
ip—User CAC per IP
- user-cac-sessions—Enter the maximum number of sessions per user for dynamic flows to and from the user. The default is 0. Leaving this parameter set to its means that there is unlimited sessions, meaning that the per user CAC feature is disabled in terms of the constraint on sessions. The valid range is:
- Minimum—0
- Maximum—999999999
user-cac-bandwidth—Enter the maximum bandwidth per user for dynamic flows to and from the user. The default is
0 and leaving this parameter set to the default means that there is unlimited bandwidth, meaning that the per user CAC feature is disabled in terms of the constraint on bandwidth. The valid range is:
Minimum—0
Maximum—999999999
