SIP REFER with Replaces Configuration
You enable SIP REFER with Replaces handling either in the realm configuration or in the session agent configuration. This section show you how to configure the feature for session agent, though the steps are the same for adding this feature to a realm.
To enable sending ReINVITES to a referred agent on an existing session/dialog:
