Holidays Configuration
To configure holidays:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type
session-router-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# session-router-config ORACLE(session-router-config)#
Type
holidays and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router-config)# holidays ORACLE(session-router-holidays)#
From this point, you can configure the holidays subelement. To view all holidays parameters, enter a ? at the system prompt.
holiday date 2005-01-01 description New Years DayTo configure a holiday, add an entry for the following parameters in the holidays element:
- date—Enter the holiday’s date in YYYY-MM-DD format.
- description—Enter a short description for the holiday you are configuring. If the description contains words separated by spaces, enter the full description surrounded by quotation marks.
