Codec Fallback Disabled
With codec fallback disabled, the Oracle® Enterprise Session Border Controller opens a channel using the codec specified by the northbound side. Since the call manager had specified another preferred codec, the result is a codec mismatch leading to a dropped call.
The following diagram shows how codec mismatches end in dropped calls.
