SIP TCP Keepalive Configuration for SIP Interfaces
To enable SIP TCP keepalive for SIP interfaces:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router and press Enter to access the signaling-level configuration elements.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
sip-interface and press Enter.
ORACLE(session-router)# sip-interface ORACLE(sip-interface)#
If you are adding support for this feature to a pre-existing SIP interface, then you must select (using the ACLI select command) the SIP interface that you want to edit.
tcp-keepalive—Enable or disable SIP TCP keepalive. The default value is
none. The valid values are:
none | enabled | disabled
ORACLE(session-agent)# tcp-keepalive enabled
- Save and activate your configuration.
