Restoring Backups
To restore a backup configuration on the Oracle® Enterprise Session Border Controller:
In Superuser mode, enter the
restore-backup-config command followed by the backup filename you want to restore to the current configuration. You must explicitly name the backup file you want to restore, including the file extension
ORACLE# restore-backup-config 02_Feb_2008.tar.gz Need to perform save-config and activate/reboot activate for changes to take effect... task done ORACLE#
Correct the Virtual MAC address configuration established on the former device to be suitable for the new device.
Establish the base MAC needed for HA operation by, first, determining the base MAC by way of the ethernet address value of the show media physical command.
ORACLE#show media physical s0p0 (media slot 0, port 0) Flags: UP BROADCAST MULTICAST ARP RUNNING Type: ETHERNET_CSMACD Admin State: enabled Auto Negotiation: enabled … Ethernet address is 00:08:25:01:08:44Apply the formula for calculating virtual MAC addressing to the MAC addressing used for this system. This formula is described in the ACLI Configuration Guide.
Configure the physical interfaces with the computed virtual MAC addressing. Refer to the following command line sequence as an example of this procedure.
ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# phy-interface ORACLE(phy-interface)# select <name>: 1: s0p0 2: s1p0 selection: 1 ORACLE(phy-interface)# virtual-mac 00:08:25:01:08:48 ORACLE(phy-interface)# done phy-interface name s0p0 operation-type Media port 0 slot 0 virtual-mac 00:08:25:01:08:48
Save the configuration.
ORACLE# save-config
Activate the configuration.
ORACLE# activate-config
