Endpoint Demotion Configuration
To configure the Oracle® Enterprise Session Border Controller to send traps and/or write syslog messages on endpoint demotion:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter to access the media-level configuration elements.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
media-manager and press Enter.
ORACLE(media-manager)# media-manager ORACLE(media-manager-config)#
- trap-on-demote-to-deny—Set this parameter to enabled for the Oracle® Enterprise Session Border Controller to send the apSysMgmtInetAddrWithReasonDOSTrap trap when applicable.
- syslog-on-demote-to-deny—Set this parameter to enabled for the Oracle® Enterprise Session Border Controller to write an endpoint demotion warning message to the syslog.
- syslog-on-demote-to-untrusted—Change this parameter from disabled (default), to enabled so the Oracle® Enterprise Session Border Controller will generate event notifications (syslog messages) when an endpoint becomes untrusted. For this capability to work, the IDS license must be installed on your system.
- trap-on-demote-to-untrusted—Set this parameter to enabled for the Oracle® Enterprise Session Border Controller to send the apSysMgmtInetAddrTrustedToUntrustedDOSTrap when the endpoint identified within the trap transitions from the trusted to untrusted state.
- Save your work.
