PreviousNextJavaScript must be enabled to correctly display this content
SIP GRUU Configuration
This section shows you how to configure the GRUU support for non-registered contacts. Enabling GRUU functionality to parse for gr URI parameter rather than the IETF standard gruu parameter is also provided.
To configure SIP GRUU functionality:
In Superuser mode, type
configure terminal and press Enter.
If you are adding this feature to an existing configuration, you need to select the configuration (using the ACLI
select command) before making your changes.
pass-gruu-contact—Set this parameter to enabled to parse for gr URI parameter in the contact header in non-registered endpoints’ messages and then pass the messages thought the system.
options—Set the options parameter by typing
options, a Space, the option name
scan-for-ms-gruu. This option forces the
Oracle® Enterprise Session Border Controller to first scan for the gruu URI parameter, then the gr URI parameter.
