PreviousNextJavaScript must be enabled to correctly display this content
Downgrading Software After Enabling SNMPv3
If you enable SNMPv3 on an SBC running C6.3.0 or above, and you downgrade to a previous software version, the software does not recognize the SNMPv3 configuration objects or attributes.
