PreviousNextJavaScript must be enabled to correctly display this content
SIP SA Continuous Ping Configuration
You can set the ping mode in the session agent or session constraints configuration. For backward compatibility, the default for the ping-send-mode parameter is keep-alive, or the functionality available in Release C5.1.0 and in earlier releases.
To configure the ping mode for a session agent:
In Superuser mode, type
configure terminal and press Enter.
If you are adding rate constraints to an existing configuration, then you will need to select the configuration you want to edit.
ping-send-mode—If to want to use continuous ping mode to send ping messages to session agents in regular traffic conditions, set this parameter to
continuous. If you want to use the keep-alive mode, leave this parameter set to
keep-alive (default).
Save and activate your configuration.
To configure the ping mode for the session constraints:
