Global Configuration for H.323
To configure options globally for H.323:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router
and press Enter to access the session-related configurations.
ORACLE(configure)# session-router
Type
h323
and press Enter.
ORACLE(session-router)# h323
From this point, you can configure H.323 parameters. To view see all H.323 parameters, enter a ? at the system prompt.
Type
options, a space, and the name of the option you want to use. In this example, the MapG729 will map H.245 G.729 to SDP G.729 with Annex B and vice versa.
ORACLE(h323)# options MapG729
