Enable the Administrative Security ACP License Password Rules
To enforce the stronger password rules and restrictions that the Administrative Security ACP license it provides, you must enable the
password-policy-strength
parameter.
- Confirm that the Administrative Security ACP license is installed on the system.
- You must have Superuser permissions.
From the command line, go to the
password-policy configuration element and set the
password-policy-strength parameter to
enabled.
The password-policy configuration element displays the min-secure-pwd-len command. You do not need to configure the min-secure-pwd-len command because the Administrative Security ACP license overrides this command with a stronger rule.You can configure any of the other password policy settings without a system override, according to the ranges specified in this procedure. For more information about the ranges, see "Administrative Security ACP License Configuration."
